Page 6 of 20 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 51 to 60 of 193
Thread: DCLS-004 Build Log
  1. #51
    You have some creative ideas going there. I'm intrigued to see where this ends up.
    The crystal cluster is something I've not seen done in a saber before. It should give a very unique look to this build.
    I like the idea of the coiled wire as well.
  2. #52
    Looking good as always hahahah
    I'm still trying to figure out 123d.. Can't figure out how to get all the detail
  3. #53
    Your brass wire on the drill is how I make the links for chainmail.
  4. #54
    Quote Originally Posted by Squints View Post
    Many features don't do it all in one. To be honest I have not seen anyone use it to the extent and with such precision. He is a master.
  5. #55
    Man, this keeps getting better and better. I can't say I'm a fan of the crystal cluster, but definitely a really cool idea I really hope you can get the removable core working. That would be awesome.
    One thing though: Don't you think there will be a bit of a brass overload if you use the brass wire tubing? Maybe a silver-coloured metal or copper would add more variation?
  6. #56
    May 2015
    United States
    1,756
    2
    Quote Originally Posted by FenixFire View Post
    Ha that's cool
    Aw shucks
    Quote Originally Posted by NanoRex View Post
    I think I've settled on bronze finish for the rib cage. There's other elements I'm not really showing yet too. Don't worry. It'll all get sorted out
  7. #57
    May 2015
    United States
    1,756
    2
    Patience. I've spent hours upon hours doing, re-doing, fiddling. For the details, start with a basic shape, then add to and subtract from it. There are a lot of videos on YouTube to help you out too.
  8. #58
    Jedi Padawan
    Sith Adept
    Jedi Padawan
    Cire Yeldarb's Avatar
    May 2013
    United States
    595
    I really actually like the look of the crystal cluster! Definitely unique!
  9. #59
    May 2015
    United States
    1,756
    2
    Quote Originally Posted by Cire Yeldarb View Post
    ME TOO!! haha
    Parts are all at the printers. Every thing checked out. I ended up putting some thin wires between multiple parts. In doing this, it reduces the component count, thus reducing post processing charges. They should arrive in about a week and half to 2 weeks.
    In the meantime, I am doing some small prep work and testing. Below you can see I've wired up the 3 pin connector to my serial cable. I'll do the same with the 2 pin and the charger cable. You'll also see a short video of an audio test I did with one of my mini speakers. I originally tested it on a Nano and was not thrilled with the result. The test on the Prizm was a little better.
    I'll hold off on any more updates until after the components have arrived.
    ***Missing***
  10. #60
    ME TOO!! haha
    Are those snap strip connectors cut down?
