Originally Posted by
wolf69
Hello,
I have been doing a lot of research and i'm still unclear about the power source.
My plan is to use an econoboard, and put a CREE XP-E, new speaker, 2 swing sensor.
1/What will be the difference of brightness on a CREE XP-E2 with an 4xAA recheargeable, a li-ion 18650 34000mha 3.7v and a 2x li-ion 7.2 (same caracteristic).
Brightness won't necessarily suffer, just battery life
2/Same question for a tri-cree.
Trying to run a tri CREE on AAs is a bad idea.
3/Is a 2x li-ion setup uneccessary for only one cree?
Yeah. 1x 18650 will do the trick nicely.
4/ difference in brightness really worth it between CREE and a TRI CREE?
If you're going to have blade effects like FoC and blaster block, or if you're color mixing, multi LEDs are needed buuuuut for a plain-Jane blade, a single die makes a surprisingly satisfying blade with very little current draw. Using 3 dice will be brighter, sure, but it's up to you if you want to cut your battery life down. Most people only use 2 dice for the blade.
5/ FoC disable with TRI CREE? I have read mixed info about this.
Not sure what you mean here
Thank you very much for you help
