Results 1 to 10 of 18
Thread: Heiland Head Piece Replica and MHS.
    Ryma Mara
    Guest
    Default Heiland Head Piece Replica and MHS.
    It says that it can be made to fit the mhs easily.
    What is needed to make it "fit"?
    Aug 2006
    Wandering the Outer Rim
    609
    Default HEILAND
    tap holes to match the head on your blade holder after cleaning and painting, MAKE SHURE TO CLEAN YOUR PART BEFORE PAINTING!!!
    Oct 2005
    3,521
    Since the blade holders are no longer as large as a sink tube you may need to use a section of sink tube or similar item to shim the head piece.
    sorry to sound ignorant....but does that mean that all of the blade holders now fit inside a 1.5" tube?
    All things a beginning have.
    As all things do an ending.
    Be not too hasty from one to the other to move, or much will you miss, along the way.
    Aug 2006
    609
    Default HEILAND
    the majority of the mhs parts will fit inside the sinktube as far as i know...
    5,899
    Quote Originally Posted by Tenric Starkindler
    Yup... except the obvious ones like the Luke and Obi ones.
    RED LEADER Standing by!
    Aug 2006
    609
    Default HEILAND
    i thought the ribbed sections would go?
    5,899
    Default Re: HEILAND
    Quote Originally Posted by jjshumpert
    Yeah... it's pretty much just the single saber pommels that don't fit.
    Aug 2006
    609
    Default HEILAND
    on the subject of the ribbed extensions, i saw a few weeks back someone had used one for a resonance chamber with slits cut between the ribs, tried it here in the shop and let me tell you this is a great idea guys, im getting sound at 3 times the volume of a stock mr with the same speaker!
    Ryma Mara
    Guest
    Thanks guys.
