Force Aware
Need help identifying a component and its value on a Nano Biscotte.
Managed to lift the part circled while attaching my power indicator resistor to my NB V2. Part was damaged.
looks to be a capacitor.. no clue on the value.
Surface mount resistor I believe, and most likely you will blow the board if you power it up without that in place. Bad juju.
dont most SMD resistors have a label/markings on it? (I believe it to be an SMD cap, not a resistor)
Sith Warrior
Force Aware
I have worked out that the part is a capacitor. I can get my hands on capacitors but I need to know the value so I can replace it with the right part. Does anyone know the series (0603 or other) and value of the capacitor?
