Jedi Ronin "Sakabato"
FINAL ELECTRONICS BENCH TEST
Greetings!
So back in 2007/2008 a buddy and I got into the saber hobby while on deployment. He ended up with a vintage graflex and a few conversion parts but ended up selling me the whole bag. With the new movie coming out, and because randomness, I bought/collected a bunch of random parts to dry fit until I puked coat hangers. I've done the prerequisite n00b question threads. Finally, I spent a couple of weeks reading my arse off. I am now ready to begin.
First and foremost: THIS IS NOT GOING TO BE AN EPISODE 4 OR FU REPLICA. Lots of other people out there have already made those sabers and done a far better job than I ever could. Instead I am going for my own personal signature saber.
Parts list updated 3-30-16!
Hilt Base:
- Vintage (authentic) 3-Cell Graflex Flash Tube
- Leftovers: Glass Eye, Clamp (sold), 2-Cell Tube (converted into screw cutting jig), leftovers from original interals
Conversion Parts:
- Graflex Blade Socket Adapter (circa 2008 ) ...bored out to accept a 1" blade/plug
- Short Electrical Pins
- Glass Eye Retention Screw
- Replica Clamp (much better fit and easier to work with than the original)
- Bubble Card (circa 2008 )
Other Parts:
- Grip Sheath, Aluminum (scrap from older saber) ...powder coated black
- Kobalt D-Ring ...powder coated black
- Assorted Screws/Hardware
- Activation Box 15
- Custom Leather Grip
- Brass MPS Insert style 1
- Assorted "found parts" for little accents and greebles.
Lower Chassis Parts:
- V5 Speaker Mount
- TCSS Graflex Chassis Disks, PC/18650 x2 and Speaker Adapaters x2
Hilt Electronics:
- Prizm Sound Module V3.5
o Pitch Black Sound Font
o Rogue Sound Font
o Calibrate Sound Font
o TFA Dark Side Sound Font
o The Schwartz Sound Font
- RBrB E-X2 Tri-Cree Star with custom copper/aluminum combo heat sink
- Li-Ion 18650 3.7V 3400mAh PCB Protected Rechargeable Battery Module
- Custom Clamp Switches (found here)
- Bass Speaker
- Assorted Wires
- SparkFun 1" Protoboards x2
- 5mm RGB LED for faux crystal chamber (common anode type)
- Recharge Port & RICE Port
HILT WORK
1) In adding the clamp switch assembly there is now a measure of slack between the battery tube and the clamp. Because of this I have decided that the lower hilt and the clamp are now going to be a single piece. Today I will be drilling and tapping set screw holes into the clamp ring and battery tube.
2) The D-Ring will get attached to the aluminum grip sleeve using two anodized 8-32 socket head screws. I've already drilled and tapped the mounting holes for the D-Ring, but need to widen (or tap) the holes to fit the screws through.
3) I can, on the other hand, get the access hole for the recharge port drilled today. The 2.1mm connector will be installed into the chassis using the TCSS acrylic disk set. It will have a window in the "reactor housing", a window in the lower hilt, and finally framed by the housing ring that also doubles as part of the grip. This will allow me to create a very low profile kill key.
4) Before I can drill the holes for the grip screws I need to dry fit the sleeves on the battery tube. Currently the sleeve is too tight a fit to get onto the battery tube without destroying the nickel plating. I don't have a means of sanding these parts on hand so I will come back to this later.
5) Since the D-ring is side mounted I don't need the original bottom plate of the battery tube. I plan to have that milled out and replaced with a brass TCSS speaker screen. More than likely I'll just end up soldering it directly to the battery tube.
CHASSIS
Reactor Housing (OD 1.39", ID 1.26")
This is basically just an insert that makes the contents of the lower hilt look "legit". It'll be roughly 4", has a resonance chamber milled right into the bottom of it, and is keyed on the top to lock onto the lower base of the crystal chamber. The outer skin will have little grooves to add some texture. Depending on how it looks once it's been machined I might go ahead and "blue" it as a final added touch.
Since virtually all of my electronics are in the lower chassis I've got room to play with the upper chassis. I will probably use some of the space I have left for the RICE port and use the rest to fabricate the "blade energy channel" and the "cycling field energizers".
CRYSTAL CHAMBER
This section is pretty standard. Most of the chamber is being built from scavenged HDD parts. I am planning on using various etched brass parts (model train and wargaming scales) combined with HDD spindle clamp disks to create a unique variant of a radiator. I'd like to do both the power crystal AND a focusing crystal... but we'll see how that pans out once I start building.
If all goes well I should be able to use the CFEs as cylinders for spring loaded struts. This will let the chassis "pop" once the upper hilt is released from the clamp. The transition between the upper chassis and the emitter will include a rotary bearing. This gives the twist action to the upper hilt to release it from the clamp without damaging it or the electronics.
~Girot
