Hello there!
I'm trying to put a custom sound for the poweron feature but only 2-3 seconds are played... there is any duration limit for Nano Biscotte v2?
Thx
Hello there!
Thx
When changing any sound files on the NB, you need to do a full format of the SD card first, and then add all your files back on. Quick format doesn't work.
If that doesn't fix the issue, you may have an incorrect value for one of the settings on the card.
I did low format the card and no luck. I believe it's something with the board's software. After the poweron, hum noise start and kill the previous sound. If I change to the hum sound, the music it's perfect till some swing or clash start.
To avoid this, I changed the sensitivity of the sensor and boom!!! Now I can play whatever I wanna without interruptions!
Sweet!
