Results 1 to 3 of 3
Thread: Help a noob with LED and resistor
    Default Help a noob with LED and resistor
    I was earlier directed on how to calculate what resistor I'd need. But for some reason I just seem to be doing it wrong. I plan on using a Red Cree LED and not sure what to use with it.
    Also, should I use a buckpuck or resistor? And what kind of difference does it make?
    May 2015
    United States
    1,754
    2
    Post your calculation. Can't really see where you think you may be going wrong.
    i saw your other post and if you are still planning on using the NB then don't worry about a buck puck.
    Also, if you want us to calculate it for you you have not given us enough information. I suspect that if you get all the information together, the calculation will make sense.
    Darth Fender
    You over estimate my FLOWERS!
