Help disassembling old hasbro vader force fx.
Hello, I was taking a look at one of the conversion tutorials for the vader lightsaber and following it to disassemble my own. I just want the blade out and im gonna display the hilt, not interested in the conversion. This is the one I was following http://forums.thecustomsabershop.com...kits-available.
I got down to the part where you pry all the wire plastic things off, and then it says I can remove the blade. I tried to, it moved a couple inches, and now no matter how hard I slam this thing it will not move. I swear I did not miss a step, the only thing I may have done wrong is not push the yellow wires far enough into the hole earlier in the tutorial, is there anything I can do to get this blade out?
Thanks in advance! PS, I've taken every screw, bolt, and pin off this thing in a desperate attempt to find out what's wrong, here is what it looks like right now. http://imgur.com/nhWTRkL
What do you mean slamming? The blade and guts should be pulled out the top of the saber.
I asked my wife if i could get a $5,000 lathe and she said "...no, but thanks for asking." : D
