Ok, I understand from the answer I got in this thread that the B3flex driver has a custom firmware developed by TCSS.
So, I have a few questions :
- Is it normal for it to turn off with a simple click. Isn't the whole purpose of the momentary switch to avoid unintentional switch offs by having to hold it down 2 seconds ?
- Is it possible to adjust the timing for the off switch function ?
or
- Is there a way to alter the programming so it can be wired in series with a soundboard and turn on and off simply by the power being injected or not in the +/- connectors ? (I am aware that chosing the latching switch config and installing a short circuit on the SWA/SWB would achieve exactly that, but I ordered a momentary config and Switzerland is far from you.)
GENERALY
- Would it be possible to adjust some parameters to adapt the controller for each project?
Thank you for your time !!!
Alexandre Ariosa
