Results 1 to 10 of 10
Thread: Correct Resistors? Ohm's Law Understanding Check
    Default Correct Resistors? Ohm's Law Understanding Check
    For my first build, I blindly followed diagrams found on these forums and managed to get a fully functional lightsaber!
    However, I want to know what's going on so I've been reading up on Ohm's law and was wondering if my understanding is correct.
    The scenario is, I have a Red/RoyalBlue/White Tri-Cree and want to mix the red and royal blue for a pinkish blade. With a NB, PeX, and 3.7v battery, the resistors are as follows:
    Red- 2.59v run 1000mA
    R = (3.7-2.59) / 1 = 1.11 which rounds up to 2
    p = (1.11)*1^2 = 1.11 which rounds up to 2
    Thus for the red die, I'd need a 2ohm 2W resistor
    RoyalBlue- 3.41v run 1000mA
    R = (3.7 - 3.41) / 1 = .29 which rounds up to 1
    p = (.29)*1^2 = .29 which rounds up to 1
    Thus for the royal blue die, I'd need a 1Ohm 1W resistor
    White- 3.15v run 1000mA
    R = (3.7-3.15) / 1 = 0.55 which rounds up to 1
    p = (0.55)*1^2 = 0.55 which rounds up to 1
    Thus for the resistor on the white, I'd need a 1Ohm 1W
    Is my understanding correct?
    Your math is fine, but you're rounding up an unnecessarily large amount for the Ohms. The Red can use the 1.2 Ohm 3 watt in the store: http://www.thecustomsabershop.com/12...istor-P22.aspx
    The Royal Blue and the White can use the 0.5 Ohm 3 watt: http://www.thecustomsabershop.com/5o...tor-P1050.aspx The White will be just fine as the FoC.
    Oh wow, I didn't realize that the store carried those resistors!
    Additional question: since I'm unnecessarily rounding up for the Ohms, how come the watts for the resistors you suggested are so much higher?
    It's what's in stock here.
    Rounding up is good for safety. Only rounding up the minimum amount is good for show, for the Ohms. For the wattage, it's just a space issue. For your resistors, the space issues aren't that significant, relatively speaking.
    got it!
    So if I wanted to make a more blue-ish purple blade as opposed to pink, I'd have to increase the Ohms on the resistor for the red die?
    That's correct.
    sweet, thank you everyone for the replies!
    Just realized that while trying to get the desired shade of purple for my first saber, I used two 1ohm2watts resistors, one after the other, for the red die.
    Is this a bad practice? I didn't have any higher ohm resistors on me at that time so I figured this would be the next best way, but are there any adverse effects of doing something like that?
    Other than it being more inflexible because you have 2 not bendy bits together, there's nothing electrically wrong with having two resistors in series to get a higher ohm equivalency. As long as they are on the same side of your circuit they are fine.
    Yeah, that's perfectly acceptable. It just takes up more room.
