Hi new on the forum so go easy on me
I'm planning on using the custom saber shop maglight ends in a par of 5 C-cell or 6 D-cell (length because I'm tall with longer arms) maglight bodies to make guard shotos. The plan is to use 3-4 AAA battery LED flashlights as the grips and 16" blades
The plan is to
- gut both lights down to bare tubes
- drill a hole low on the back end to fit the grip
- grind out any material left inside main barrel of tip from the smaller one
- install electronics using the led lights tailcap to use its switch for the saber and house the batteries
- modify original switch hole in main barrel to use for speaker then disguise it with a leather cuff with decrotive slots.
- wire in modules and lighting
I would like to use sound but I'm open to not having heavy lighting effects to begin with. I.m doing this on a budget so I need some assistance on what lights and sound items I would need that will work with the maglight housing while keeping the cost down. My only big requirement on the lighting is that is gets a good dark purple glow.
I would like to use the original plastic bulbholder assembly to hold the lighting even if I have to modify it it's already made to fit so why not keep it?
images of what is being used
body
Blade holder (thanks to CSS)
Tail cap Just for looks
heres what I want it to look like when finished basically. most of the body will just be empty space
