Results 1 to 8 of 8
Thread: What's the deal with blade tips
    Question What's the deal with blade tips
    I really like the 3/4" blades but can you get bullet tips for them? (cos they do look better). I've only seen round tips, either pre made or separately. The 7/8" and 1" sure no problem but the 3/4" nothing!
    There used to be bullet tips available. I guess he's not offering them any more. Not too many using 3/4 anymore. They're too flimsy for dueling. They do look better on a skinny hilt though.
    Don
    Sith Happens
    Ok. So if I split the difference and go with a 7/8" blade does it need a reducer cos i assume it won't sit tight in the BH and a blade retention screw will push it off centre. I don't see anything in the store other than the 1" to 3/4" reducer
    You can use a small section of thinwalled 1" blade stock as an adapter for the 7/8" blades.
    Uh! Obviously! That's worth a face palm. thanks SS
    If you don't have any thinwall scraps, shoot an email to Tim before you place your order. I'm sure he's got some cut pieces available.
    Thanks SS I will do that. Although, if the force is with me, this might work......Attachment 11512
    Get out your calipers. If that material is 1/16" thick, it should do the job nicely. You might need to make a hole in it for the blade retention screw to pass through, but I don't otherwise see an issue.
