Glad to know my work is worth replicating
I notice you've got the tubes in a square pattern. I know it's a rough design that you've drawn up, but keep in mind that when you make the final pieces you'll want to put them in the same sort of hexagonal pattern that the slots on the MHS chamber are in, that way your tubes don't block your view into the chamber.
My second concern is where you're going to try placing the chamber on the hilt (which is extremely long for a standard hilt haha). Where it is right now, the top of your chamber is going to be taken up by the heatsink from the LED star in your emitter piece. Personally I would consider putting the chamber below the choke section, as it's more lore-friendly, and more wiring-friendly, but it's just my opinion. I took the liberty of showing the differences using the MHS builder.
