Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: My first build i need help
    First thanks for the fast responses.
    anywho if i remember from the video, Madcow Bridges(?) both the positive and negative pads for both die. i understand he is a professional, and i'm probably over complicating this for myself.
    Yes, he does bridge them, but with that said, in this case, you shouldn't. Use the separate wires method I mentioned earlier, and your life will be much easier.
    time to do some research about the best way to do this. i dont want to bother you with something i could just as easily look up.
    Thanks for the clarification, i had a feeling i was over complicating it.
    just a quick clarification. even though the source voltage is slightly higher than the royal blue forward Voltage. i calculated i'd need a .19 ohm resistance, so probably a .2 ohm resistor. should i resistor it to be on the safe side or does the small difference matter all that much?
    You should put at least a minimal resistor on it. Think of it as "insurance".
    That's what i'm thinking. i might have to resistor the red more than i planned but it'll be worth it.
    thanks again.
