Only reason i MENTION radioshack is because my local one is still up and running for the moment.
I think I'll be going with your option.
Which resistors would you recommend work best, and for which sides?
Jedi Padawan
Sith Adept
Jedi Padawan
The resistor you choose for the Red die will depend on your battery setup (sorry if you posted it already and I overlooked that detail). You can use FJK's post about Ohm's law to figure out the resistor value or use the calculator in SS's signature.
For the Pot, I can't say exactly what you'll need either. Personally, I popped over to the Fry's Electronics by my work and got a Pot with a range of 0-1k ohms (simply for the reason that all of the other ones they had had even higher maximum resistance values, and for what I was doing, even the 1k maximum was unnecessary). I wired it up in-line with my LED and, starting at 0 ohms, worked the resistance up until I was happy with the color that had been mixed. If you have a volt meter, you can then just measure the resistance of the Pot and replace it with a comparable resistor once you know the ohm value you would need, but that is not necessary.
