You've got a 14650 side-by-side battery pack. The acrylic chassis discs for 14500 packs will work.
http://www.thecustomsabershop.com/Ac...s-S6-P764.aspx
You've also got a BuckPuck. There's a set of chassis discs for the MWS BuckPuck:
http://www.thecustomsabershop.com/Ac...k-S7-P767.aspx Those should hold your BuckPuck, though you may need a little foam tape on the bottom to hold it secure, since you don't have the MWS version.
From there, it's just threaded rods, nuts, possibly the metal spacer tubes if you want them.
But this is just one option. You could also make it out of PVC pipe, use the metal chassis discs and secure with foam tape/zip ties/velcro straps, or even some method of your own devising. The important thing is to ensure that the parts don't bounce around, and that they don't make unwanted electrical contact.
