Results 1 to 3 of 3
Thread: Check my work
    Question Check my work
    Hello,
    I am making my first saber here using the tools. I used the MHS Builder for the hilt and am wondering if I used the correct electronics for a MWS setup.
    My battery pack: http://www.thecustomsabershop.com/2A...ctor-P722.aspx
    LED: http://www.thecustomsabershop.com/Re...dule-P653.aspx
    Switch: http://www.thecustomsabershop.com/MW...ches-P753.aspx
    I have a few questions however. First of all, the MWS 1000 mA BuckPuck is out of stock currently, is there a way to wire it with a resistor (preferably with no soldering)? Also, is it possible to use a AV switch or any other standard electronic parts with the MWS? Lastly, can I add a recharge port such as this one: http://www.thecustomsabershop.com/MW...Port-P877.aspx and if so, how?
    Yes, you can use a resistor for the LED. I am assuming you are using amber... with two AA batteries, you will need a 1.5 Ohm/2 watt resistor. (it is worth noting that if you decide to go with the buckpuck, you will need 3 AA's to properly drive it)
    The AV switches are momentary switches, and will only work with a no-sound setup if you use a latching converter: http://www.thecustomsabershop.com/Mo...-70v-P928.aspx (this will require soldering)
    The recharge port is best used with hard-wired Li-ion batteries. With your setup, it would only be useful if you want a kill key. (if you would like help with wiring, I can draw up a simple diagram)
    "Everyone who drinks this water will be thirsty again, but whomever drinks the water I give him will never thirst."
    Right, so I am actually using a Royal Blue bulb, I guess I have the wrong battery pack then. Could you draw a diagram with the resistor and recharge port?
