Results 1 to 6 of 6
Thread: Using a Z6 RGB?
    Default Using a Z6 RGB?
    Hello everyone! I am currently planning a multi-color saber build, and I was wondering how to make the brightest possible blade. So after some google-fu, I found this. Is it possible to wire this LED to a Prizm or Petit Crouton soundboard?
    Thanks so much!
    -Moonpopper
    Last edited by Forgetful Jedi Knight; 04-04-2015 at 08:39 PM. Reason: Link removed - FJK
    Quote Originally Posted by moonpopper87 View Post
    Thanks so much!
    -Moonpopper
    Those should be able to be used with a Prizm, but not the PC. As par as "brightest blade" part of your statement goes the new Tri-Cree LEDs that are sold here in the store would do just fine for your purposes.
    Thanks so much! After looking at the prizm manual, I assume that I just bridge the positive solder pads to one another and negative pads to one another in order to connect them to the board?
    I'm not familiar with how the Z6 gets wired up, just that it uses a common anode, and how it performs against other LED solutions. That is a product that isn't sold here in the store.
    As FJK said, the tri Crees from the store will be brighter, due to having more balanced optics and using better emitters.
    Quote Originally Posted by cvsickle View Post
    Okay. I will probably go with a tri-cree then! Thank you all for the help!
