Results 1 to 4 of 4
Thread: First build; I think I damaged the threading...
    Default First build; I think I damaged the threading...
    Hi everyone, I saw a similar thread, but the circumstances seemed different, so I decided to make a new one.
    For reference, I'm using an MHS v1 type 1 hilt and a type 17 blade holder. Of course, because of the uneven design of the blade holder, I used some clocking washers and it matched up well, but that made a bit of space between the holder and the hilt making the LED module click around. I thought maybe I can put a thin rubber band in there to buffer that space; unfortunately that didn't work.
    This is where the problem starts: I tried to put the holder back on to the hilt, but now it doesn't match up properly. Not to mention that when I screw it on, it makes this scrape-y/scratchy/squeaky noise, leading me to believe that the threading is damaged.
    Just to make sure, I screwed the blade holder on to the other side, and it went on smoothly, so I'm convinced that the damage is on the hilt.
    I apologize for the wall of text, but this is the question: is there a way to fix this, or am I SoL and should replace it?
    Clean the threads with an old toothbrush and a can of air, lubricate (lightly) and try it again.
    Aside from the threading issue, did you get the size 2 clocking washers or the size 1? If you're installing them next to the blade holder, you need the size 2 washers to make things fit properly, or else the heatsink will be loose and move around a bit. The size 1 washers go everywhere else. Rewatch the video in http://forums.thecustomsabershop.com...Threaded-parts if you're still unsure.
    Check the threads with a piece of tissue paper. Run it along the threads with your finger. If it catches anywhere, clean the threads with a bit of fine sandpaper and a gentle touch. Wash the part, use an old toothbrush to remove any grit, dry, and retest with tissue paper. So long as the parts haven't seized together, it's fixable.
    Thanks to everybody for helping me out. I tried as you advised, but it still wasn't working, so I worked on one of the clocking washers with a whetstone, and I got it to work again.
    So crisis averted. Again, thank you all for your advice!
