Results 1 to 10 of 59
Thread: May the Force be with me. My first saber build
    Default May the Force be with me. My first saber build
    Parts.jpgAnd so it begins. With the help of a lot of great Jedi Knights or Sith Lords (Not my place to ask ) I am now getting started. I have not come up with a name yet so throw your suggestions out.
    Best of luck to you! Take your time, don't work when you're tired or frustrated, and you should do fine.
    Does it matter what type of resistor is used (wire wound or metal oxide)or, as long as it matches your needs it does not matter?
    It can, but mainly due to the metal type resistors having the possibility of shorting against the inside of the hilt should their coating become damaged or scratched. Try to stick with carbon type or ceramic if possible.
    Running slow but here is a pic of the LED wiring. I an using the red,green and blue to match the LED's.LEDs wiring.jpg
    Looks neat
    What sort of chassis infrastructure are you using to hold it all together?
    Call her... "Tempest"
    Cad-Bayne
    I was thinking about PVC chassis but might re think it. Tempest is a good name. Any meaning to it?
    tem?pest
    ˈtempəst/
    noun
    noun: tempest; plural noun: tempests
    a violent windy storm.
    synonyms: storm, gale, hurricane;
