Force Aware
Choosing a single resistor for two LEDs in parallel is generally not wrong.
However, this way you are doubling the current passing through this resistor you respect a single LED and will need double the wattage, and you did your math correctly.
The problem with this solution is that internal space is a main concern when building sabers and a 4W (or more likely a 5W) resistor is definitely huge.
I normally prefer to use a pair of 2W resistors (one for each LED) since they are smaller than the 5W and even using two of them you save space inside the hilt.
Ok this is what I needed to know, you guys are great thank you (:
