Results 1 to 4 of 4
Thread: A little help
    Default A little help
    Back in 2011 I had all intentions of ordering my parts to build my saber. For some reason it never went through. O well. But now I want to build it part by part when I can afford to buy stuff. There was some mill work in the list that I am kinda confused by. Maybe someone could enlighten me on what I was thinking.
    Things have changed a bit since 2011. You might want to start over and give yourself a chance to review the new options available. For one, the new LED heatsinks don't use the nylon screws. We use a thermal adhesive pad instead.
    I see you have holes for the switch box, the blade retention screw, and for mounting your covertec button. Nothing out of the ordinary.
    Thanks for the advice. I have looked around and it seems like Im out of loop with what is new. I can tell just by looking at sound card models.
    I agree with SS, you should really just start over.
