I made this a while back after finishing my saber. I suppose it could be done with or without the charger.
Parts I used were:
An old lamp base that I took apart, I think I got it from Target. It was a long time ago but I am pretty sure they still make them. Like 10-15 dollars.
Sink tube 1.5 inch diameter from Home Depot. Cut with Dremel.
Rubber washer 1.5 inches outer diameter and, I don't know, whatever diameter the charge ports are, in the middle.
Felt from Michael's to replace under the base.
Gorilla Glue (to keep the weight inside the base after taking the screws out, I would really load it in there and leave it for a day or two)
Krazy Glue (everything else, including keeping the sink tube on top of the base)
Also put two little strips of felt on the inside of the sink tube, they don't go all the way around because the hilt wouldn't fit in that way.
I should take some more pictures and post them, for now I just have it with the saber in place.
