Results 1 to 10 of 12
Thread: nano biscotte v1 led resistor
    Default nano biscotte v1 led resistor
    Hey every one, i have a quick question im having trouble answering my self by searching the forums and google. I want to hook up my ledengin dental blue 5w to a nano biscotte v1. Do i need a resistor to the led if i am using a 3400mah 3.7v 18650 battery?
    Yes, it's highly recommended.
    Thank you. What resistor would you recomend if i want to run the led at 1500 ma ?the board puts out 2000ma if im not mistaken so would i need to do olms law to figure what resistor i need?
    Yes, you would need to use Ohm's Law. I wrote a tutorial on that and it's floating around here... somewhere..
    Sweet i found the thread thank you!
    As FJK, and SS always say: Ohm's law learn it, and it will be your friend. I would only add, don't learn it and you will be spending more money on parts.
    Don't forget SS has a resistor Calculator in his signature.
    I do. The one in my signature rounds up to the next standard resistor value, even if you could get by with a slightly smaller one. Using Ohm's Law is the best way to get your resistor value, but a calculator is nice to double-check your work.
    LED calculator: current limiting resistor value
    Source voltage 3.7
    diode forward voltage 3.7
    diode forward current (mA) 1500
    The wizard recommends a 2.3 Watt capable or greater 1 ohm resistor. The color code for 1 ohms is brown black gold.
    series connection diagram
    would this be the correct resistor ?
