Waiting for parts now. Thanks again for everything.
Dave
Dave
I give up man. I decided to use the "modular wiring system" for my first project. I don't know what is wrong with this. The switch led lights up when the kill key is removed, the main led lights up when connected directly to the battery, but the main led will not light up even when I connect the battery to the resistor to the switch to the Led.
I would need to see a close up of the bottom of the switch to be sure, but I am guessing you don't have it wired right.
How it looks so far
You have the main LED plugged into the two switch terminals. There's no power going to the main LED.
The MWS switches are designed to be plugged into a sound board. Did you get the prewired *momentary* or the prewired *latching* switch? If you got the momentary one, you'll want the prewired momentary-to-latching converter. http://www.thecustomsabershop.com/MW...rter-P932.aspx
If you have a latching switch, you'll need to get out your wire cutters and soldering iron. Follow the wiring diagram I posted earlier, and you'll be up and running in no time.
Wimped out and bought the MWS buckpuck. I'll solder next time. Thanks again for all the help. Still working on a blade though. Bought the thin waled trans white with the white pointed tip, not too pleased with it but have to try some diffuser tecniques withe some clear wrap from micheals. I'll probably just post pics up on the gallery thread after that is done.
Really appreciate the help though. Thanks guys.
