That is definitely wired incorrectly. You have what appears to be a DynaOhm on your main POS+ line from the battery, which is limiting ALL your current to just 20ma. You also have another DynaOhm on your main LED. The amber Rebel LEDs take 700mA.
It's an old diagram, but it'll work. The orange dot is the resistor for your switch LED (DynaOhm goes here). Negative from battery goes to C1 on your switch, and the NO1 terminal on your switch connects to the LED- terminal on your switch AND goes to the main LED. You can use a resistor or a 700mA BuckPuck for your main LED.
