Is there a wiring diagram for the Switch 22? It has four prongs, all the A/V switches and Momentary switches are three prong... Anyone? I am considering this switch for sound font changes. All help would be appreciated. Thanks everyone.
Grab your multimeter and check two adjacent terminals for continuity while the button is pressed. If you don't get continuity on those two terminals, check a different set of two until you get continuity with the button pressed.
1 2
3 4
Check 1 and 2, and if that doesn't work, try 1 and 3. One of those two combinations should work.
I remember using the 2 prongs on the same "side" of the switch, but definitely use SS's method to check it.
They're fragile during installation... but haven't had one fail yet once it was in and braced. Get an extra one or two, just in case.
It depends on your installation. I've used them a few times projecting out the sides of a Box 8, and wedged a piece of plastic tubing from a hobby shop as a brace behind it to the box wall once the switch was set in place. I've another installation where there's nothing behind them, just a wicked snug fit into the card they're setting in, and have had no problems. They don't like twisting, which can happen trying to push them into place, and that's when I've had them come apart. Use a flathead screwdriver (or some such gizmo) to gently convince it into place.
I checked, and of course I've no pictures of the braced install in process. Sorry.
They will 'snap' into a 13/64" hole. Sometimes, they're a hair loose and some Gorilla glue around the neck takes right care of that. As said, do NOT try turning them once they're in place or they'll break easy. I use a small piece of 1/2" dowel to push them into the hole flat, so there is no twisting.
GET LATHED!
