First Build parts list, help please
This is my first build, I was wondering if anybody had any input or suggestions for the wiring of this saber.
The Hilt
MSV1 Blade Holder Style 6 - http://www.thecustomsabershop.com/MH...le-6-P186.aspx\
MHS Choke Style 3 - http://www.thecustomsabershop.com/MH...le-3-P313.aspx
MPS Pommel Style 4 (Machine recessed 16mm AV switch hole) - http://www.thecustomsabershop.com/Hi...e-4--P866.aspx
MPS Insert Style 6 - http://www.thecustomsabershop.com/MP...le-6-P263.aspx
MPS Clip - http://www.thecustomsabershop.com/MPS-Clip-P72.aspx
Rebel Star LED & MHS Heatsink Module (Luxeon Rebel Star Deep Red) - http://www.thecustomsabershop.com/Re...dule-P653.aspx
16mm Anti Vandal Short Momentary Red Ring Switch - http://www.thecustomsabershop.com/16...itch-P580.aspx
4AA Battery Holder with JST connector (6v) - http://www.thecustomsabershop.com/4A...ctor-P723.aspx
Now for the part that I am confused about. According to the guide here, using a Red LUX III with a 6v battery, I am to use a 2.2 Ohm 5W resistor which connects from the positive part of the battery to the positive part of the LED module. However, If I am going to use the AV red ring switch, I read that I am supposed to be using the 220 Ohm 1/4W resistor (I am unsure of the set-up). I am having trouble visualizing the set up of using both of the resistors. Is it supposed to look like this?
Please help me as I am very confused. Thank you
