Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
Thread: Power level indicator
    Default Power level indicator
    Corbin has a sweet looking Power Level Indicator...
    http://www.corbinscomponents.com/PLI.jpg
    It got me thinking of smaller, less complex ways of doing the same thing. But alas, I don't have the electronics expertise required.
    I want to do something that's the size of 3 small LEDs or smaller. Does anyone know how to make a small circut that would have its own momentary button, when pushed would activate a green, yellow or red LED depending on whether the battery is fully charged or low???
    Or... is there an LED out there designed to do this already?
    MC
    There are some designs out there. Do-Clo may know where to get ones that are not already in devices.
    otherwise it would just be a matter of making one up.
    Mar 2006
    2,319
    I don't think this is quite what you're looking for, but you may still be interested in it.
    As posted before...
    It's an On-Off (Latching) Power Level Indicator and Recharge Port all in one.
    Unfortunately it is much bigger than Corbin's and it's not momentary. I just thought I’d give you some ideas.
    Read the Thread Index. because Lord Maul fixed it...
    I'm still hoping someone can post an online source to that switch, as my local hobby shop looked at me like a deer in headlights when i asked about it.
    Mar 2006
    2,319
    Quote Originally Posted by Dregan
    lol
    I'll see what I can do.
    Check back later.
    Edit:
    Here's a link to one
    http://www.maxxprod.com/mpi/mpi-4.html
    I'll keep looking for more options. I'm not having much luck.
    So are the prices of this joint at least comparable to what you got locally or do we need to get you to be the distributor.
    Mar 2006
    2,319
    Quote Originally Posted by james3
    Yes they are.
    But you'd have to pay shipping online, so you have to add that to it.
    FB, how easy would it be to take that thing apart and use the guts in a saber?
    MC
    Mar 2006
    2,319
    Quote Originally Posted by Madcow
    MC
    I don't know...
    It appears to be glued together (no screws anywhere), so I'm guessing that it would be quite destructive...
    I was thinking the same thing.
    Garrity makes an LED flashlight that has a (3) LED power indicator. The board also has the microswitch for the power. I'm thinking of intergrating this into a lightsaber. The power level LEDs are Green, Yellow, Red. They flash when it's not in use to indicate the current status.
    The electronics are already designed to be in a round tube. Trick is getting it to drive the Luxeon LED.
    -Del
    Kicked out of the Sith Order for being too chipper!
    My website - http://buttrynet.dyndns.org
