Parts list for my first saber
O.k., finally have the finances to complete my saber. Here is the parts list, and the usual question, am I missing anything?
Body parts
Pommel style 3 version 1
Hilts style 2 guarded style switch hole
Ribbed grooved choke combo
Blade holder style 23
8-32 3 inch thumbscrew to hold the blade
Nano Biscotte sound module v2
Panasonic Li-ion 18650 3.7 volt PCB protected rechargeable battery
Premium 28 mm speaker
rebel star led & mhs heat module
MHS speaker mount 3
MWS Short Momentary 16 mm av switch
My question would be would the switch work with the guarded switch hole?
make sure you purchase the service for drilling the blade retention screw hole unless you plan on drilling and tapping it yourself.
the AV switch will not go into the guarded switch hole. either purchase the hilt with a recessed switch hole service instead of the guarded, or get a guarded momentary switch from here.
http://www.thecustomsabershop.com/Gu...Style-C63.aspx
also, you might have missed a pommel insert (don't forget to get the clip as well)
how are you going to hold the electronics in your saber? you can get chassis disks or you can get the speaker mount v6
lastly, it would be a shame not to use the flash on clash feature when you have it available. I highly suggest getting a tri-rebel and power extender.
hope this helped!
