Ok, so I finally started building. I ended up abandoning the recharge port because it would not fit with my current dimensions. So much for my planning. Didn't realize that AV buttons would block chassis, but you live and learn.
So i modified my schematic to the following:
I wired it up, then plugged in the battery. The AV light turned on but nothing else would. I rechecked my wiring. Everything looked good. Then I noticed the dynaohm for the AV MWS part from TCSS was on the red line. I wired black as positive. Doh. Okay, so I re-wired everything. Plugged it in, AV light comes on but nothing else. I check my wiring again and, like an idiot, when I re-wired everything I put the LED- wire on the momentary pad and vice versa. Doh ^2. I de-solder these and swap them. Plugged it in, it made a clash sound. I pushed the AV and I heard the ignition, the main LED came on, and there was a continuous string of swings and clashes. I thought it was just sensitive (all the board is sitting in its chassis on the table) so I hit the AV and it de-ignited.
Awesome, it seems like it works. So I unplugged all my JSTs and loaded it in to the hilt. I plugged it in, the AV lights up and there is a clash sound. I hit the ignition, and I get nothing. I unplug all the JSTs and reconnect them, then do it again and I get the same result. I take the chassis out of the hilt and check all the wiring plus the connections, suspecting I pulled a wire loose in the cram-fu process. The wiring is as I planned and there are not loose wires. I deduce the following:
1. since the AV light comes on, I know the power is coming out of the battery properly.
2. since the speaker is making the same clash sound each time it is powered up, the board must be getting power and sending it to the speakers. That means Bat+ and Bat- as well as Sp+ and Sp- are wired correctly.
That leaves the LED pad and the momentary. I figured that problem is probably the momentary pad since this is upstream of the LED. I de-solder this and re-solder it. I leave the chassis outside the hilt and plug everything in. Now, the AV lights, the main LED comes on for about 2 seconds, and I hear the speaker boot up. Then the main LED goes off, the AV Light is still lit, but hitting the AV button does nothing.
I am at a loss now. Given the variable behaviour, it seems based on my reading that this suggests a short. I have looked over every connection on the board probably 15 times from both the top and bottom view. All of my wire splices that I did were tug-tested and shrink wrapped. I have included images of the board below. The only thing I can see is that the Sp+ and Momentary pads have a lot of solder and they are close, but the are not touching. This is actually a little uglier than right before my last solder-desolder as the soldering job was cleaner before i tried to re-do it, and it was not working properly then either.
Thoughts? I appreciate any help...
<yes, I realize I'm not the sharpest tool in the shed having had to re-solder literally 4-5 times because I can't follow a basic instructional...hopefully this did not damage the board...>
