A few thoughts:
1) I have both types of 40" "thick" blade material from "the other guys" (before I discovered TCSS), and I'd say which is "better" is a matter of personal preference. The clear gives more of a "tube within a tube" effect when lit, and some effects like shimmer and pulse are more noticeable with the naked eye in "daylight" conditions. Also when unlit, has a silver look. The trans white does tend to more uniformly light up the length of the blade, but is a smidgen more "washed out" in "daylight" conditions. Also when unlit, looks white like the toy blades. With that being said, there are many MANY variables that go into how a completed blade will look. Your LED, (color, and how much juice you drive it with), the diffuser/cellophane and how much you use, the LENGTH of your blade (most people don't think about that) and the reflective (or semi-reflective) tips.
2) if you are trying to do this "on the cheap" (or a budget) a cost benefit analysis may help. As yes, it may be cheaper to build your own blade, IF you get only the exact materials you need (and don't mess up), but I've read that like most parts of this hobby, proficiency comes with practice, and trial and error, and that means materials and $. For the record, the store sells complete blades (like this:
http://www.thecustomsabershop.com/LE...-OD--P198.aspx) that isn't too much more than building one yourself, AND you KNOW it will be done right, and may be worth the few extra $, and saving of the headaches.
