The Vader MR has one clash sound... thus the Maul too.Originally Posted by 987654321a
You should be
You should be
RED LEADER Standing by!
You can argue with me here if you want, but I believe there are 2 jedi sound boards. Theyre similar but slighty different. My Luke sound board I bought here sounds exactly like my Mace and a broken Anakin saber i recently bought. However, my orginal Anakin that I converted a couple months ago, (its the version with a DIN plug in it) has a deeper hum, is louder, and has a different sounding power up/down. Like I said, you can disagree with me if you like, but Ive done rigorous comparisons.
RED 7 Standing by...
omg i was completely thinking about something else, i was thinking about the sound when you move it. my bad everyone.
Darth Sequentius...Sith Lord
Bringing light to darkness.
ha, CD got owned.
silentbob - james and i already argued over this one. ultra came in in the end and said that there are only 2 sound boards, the sith and the jedi. the only difference in the sounds is due to the echo or somethin like that.
well pyle i didnt get owned but i just was in a different state of mind.
Pyle. You are not worthy of comments such as that.
For one, Countdown didn't get owned if it was a legit goof. And two, he admitted said goof an hour before you felt compelled to spout off.
Now as for the FX sound board thing.
First off, using a Corbin driver for the LED and the FX for sound is like the Supreme setup. You get about as good as it gets for a 3watt setup.
For a bit less complex setup use the FX board.
There are some other options as well.
I have some more info on the FX I will have soon.
Well Maul, all I can say is your not here listening to both of them. They sound clearly different to me, and if you dont have sabers to compare yourself than you really cant say anything intelligent on the matter.
so i can buy a broken fx saber and have the same effects as a corbin? or worse than corbin? if im going to spend money on my lightsaber...i want it to be awesome. what do yous guys suggest? i want all the effects...coring, clash, extend, retract, everything!
If you want all the snitz, then use Corbin's driver to run the LED. Use the MR/FX for sound.
There are some new things coming but for now that is the top dawg.
awesome...also have you had any problems with the wires breaking inside the lightsaber, mine have like 3 times. kinda annoying. i have to order a new switch now....it broke right at the switch so i cant fix it.
