insert clip help pls.
I have a pommel, an insert, and a clip.
I have the insert in the pommel.
How do I lock the clip in place?
You need a good set of c-clip pliers, you put the insert in the pommel, and then using the c-clip pliers, squeeze the clip together, insert it right oboe the inside of the pommel insert, and then once it's in place, you can "unsqueeze" and it will rest in the indentation at the bottom of the hilt. When you insert the clip in, the side with the rounded edge should be facing down (toward the clip).
i'll see if I can borrow a set of those from the mechanics at work.
