Thanks! I got the chip up and going!
Now, to connect the sensors...
Any suggestions?
<EDIT>
Oh, oops, I forgot...
How do you loop a sound?
Any suggestions?
<EDIT>
Jakim Fett
Bounty Hunter,
Jedi Master
Sabersmith.
And sometimes
Darth Inferno,
Sith Extraordinaire
Another problem I have run into is that I need to change the address of the chip, reset the chip, and then play the sound. When the sound has finished playing, I need it to go back to playing the "Hum" sound. If someone can help me with this it would be appreciated.
Jakim Fett
Bounty Hunter,
Jedi Master
Sabersmith.
And sometimes
Darth Inferno,
Sith Extraordinaire
To do proper sequencing and adress control of the chip, you might need a microcontroller that can be programmed with various ways. A "basic stamp" could do the job. This actually could also be done by a cmos chip of the 4000 serie : the 4017, plus a bit of logic, I used to implement grafcets this way.
Erv'
Props Electronics
http://www.plecterlabs.com
Thanks!
Jakim Fett
Bounty Hunter,
Jedi Master
Sabersmith.
And sometimes
Darth Inferno,
Sith Extraordinaire
any updates about your electronic project ?
Props Electronics
