Two Aux Switches
Is it possible to wire up two auxiliary switches at the same time? So if either are pressed the aux sounds will be played?
Sure, you wire them in parallel. That way if either is closed, the circut is completed. The important thing is - do you have room? you'd be surprised how fast that litle space fills up. I would suggest 1 wire going to the pads on the sound board (easier to solder) and then maybe srtringing the 2nd switch off the first one. It kind of depends on the placement.
