Just thought Id try both and show the comparison. Left one is all 3 in parallel and the right is just two. Theres the proof 2 is better 3 with the nano
I can light a small city with my board
Wow, actually both are quite bright!!! That's a blade which should come with protective Googles...
I have to make by the way a correction to what I've written before. I was curious about the 2A Limitation we had been discussing, so I asked Erv as the only source of truth when it comes to his products. As Forgetful Jedi Knight mentioned absolutely correctly, 2A is not a limitation. Technically it's a so called absolute Maximum Ratings, which means if the user/application goes above this value, there is no garantee the device will work and damage might occur. But the current flowing will be determined by the load you apply, so you have to ensure no more than 2A through all your LEDs (despite of the substantial safety margin of the driver).
Of course with increasing current the voltage drop over the wiring will increase as well (wires can be considered resistors, U=I*R), reducing the voltage to the LEDs, which in turn reduces their intensity. It would be quite interesting to measure the voltage between the anode and cathode of the LEDs in the 2 and 3 LED setups of yours.
One thing to note for Tri Rebel setups with FoC. If you're using a Power Xtender for NB FoC (and you really must), while a small amount of board current is used via the FoC pad to activate the Power Xtender, the main drive current for the FoC is drawn directly from the battery, bypassing the board itself. Bear that in mind when making your calculations.
