You diagram for wiring the LEDs looks pretty good, though you WILL need a resistor for the White FoC. I strongly recommend using a Power Extender to help with that little task. However, you don't have the other components in your diagram (recharge port, RICE, etc.).
Also look at the diagram in post #17 int his thread:
http://forums.thecustomsabershop.com...Rebel-Star-RRW
You will need a fairly large resistor if you are going to run a single white FoC dice. Doing that on the sound card itself can generate more heat than the sound card likes, which could damage your card.
As far as learning about resistance (and resistors), you may want to read this tutorial over a couple of times:
http://forums.thecustomsabershop.com...esistor-Values
I will be a sport and tell you that the the typical forward voltage of a white dice is 3.2V.
Well, of course I have no intention of damaging the card!
I will try to understand as much as possible by reading the tutorials that I have indicated.
Thank you!!
