Hello fellow MHS enthousiast
Hello Tim
As I am on my lightsaber building process I'm about to wire my CF7ds with a 4 dice led.
I learnt from the more experienced that right now the new XP-E2 leds are the top choice for green AND red
Off course I use MHS system and here is my request from my tests:
The PCB used for theses led is this
http://www.ledsupply.com/leds/cree-x...high-power-led
So I tried it with the v4 led holder and despite the bigger size the MHS part is doing the job very well
The copper heatsink dont need to be change in diameter, fits perfectly!
The aluminium holder would need a very minor adjust in diameter to fits the optics provided (carclo).
Then I would need to know if it could be possible to have heatsinks a bit differents from the V4, with very minor changes:
1) the holes thru the copper, same diameter but not 6, just 4 holes fiting the quadpod support with the same diameter (the diameter of the MHS heatsinks are exactly the same than the quadcore but should be placed )
These holes allow 2wire 24awg silicone to go thru 1 hole.
2) a bit more longer copper heatsink on the thread: this is the zone the heat is sinking to the aluminium, I'm also going to use thermal paste in this area. Quadpod mean 3 dice working at the same time (+1 foc): more heat to sink
For the aluminium part I will modify them myself in order to get the sabers prototype faster but the copper part is very more sensitive to my hpov: titanium dont sink heat that much I care about frying my system.
I have found 2 quatro optics
Kathod and carclo
Kathod lens fits the leds but not the quadpod PCB
the Carclo is shorter
As said before silicon 24awg wires can go thru 1pcb holes, pcb hole are the same diameter than the copper's holes)
The question I have to answer
witch lens would work better? I have to finish the cram-fu to power it.
Annnd the pics
left Kathod, right Carclo
sorry for the pics, as my camera is dead I shoot the photos with my phone witch allow me to post too..
