Results 1 to 3 of 3
Thread: Will a seoul P4 LED work for a Vader conversion?
    Default Will a seoul P4 LED work for a Vader conversion?
    I would like to use a Seoul P4 white LED instead of the rebel star for my MR ESB Vader conversion.... should that be a problem, or do I literally just do the conversion exactly like I would if I was using a rebel star?
    The conversion works exactly the same for both the Seoul and Lux. Rebel Star. The only difference is the LED and the lens+holder. A long time ago, I did a Hasbro Anakin with a Rebel Star, then switched to a Seoul P4 later.
    Quote Originally Posted by Yoshi-Taka View Post
    Awesome, thank you so much!
    I think the Seoul is a bit brighter, and I know they don't make it in red, but I saw that they had those little red disc looking things I can put under the blade to make it red.
