Simple question if i can explain it well enough. I want to have a tri rebel rgb wired with all three die in parallel to a dip switch. Each die will its own resistor based on its current needs. My question is what happens if i turn on two die at once? Will the resistor needs change? Won't each die be getting half the current? Would this setup require having two resistor choices per die, one for running them each by themselves and one for running them with a second die? If that's true, i suppose i could put a spdt switch on each + lead for each die. I could switch each one betwen "lone gunman" and "buddy system" mode. That's a lot of switches and resistors to cram fu.
Is the an easier way to do this?
