A higher voltage won't help if you're running all the dice in parallel. All you need is sufficient voltage for the highest Vf of the Tri-Rebel dice (3.4v)
Okay good to know. Thanks Silver. Just one more thing, someone was good enough to direct me to this diagram. I don't want to come off that I don't trust him but I'd just like to corroborate with at least one other person that this is a correct wire up for a tri-reb color changing saber. wiringrgb2_zps0ccf012f.jpg
That diagram is correct.
hmmm, there doesn't seem to be a 2.2 ohm 2 watt resistor in tcss. :/
This helps me as well because I was wondering about the Tri-Rebels. Like can you use a 4 AAA battery set up with said resistors?
"Your move!" -Obi-wan kenobi-
