Posting this for a friend. Helped him try to figure out what's wrong... He pieced together a NB using JST connectors to put in a converted Graflex. For a switch, he had a momentary tactile, but had accidentally soldered the 2 leads on the same side of the switch instead of one on either side, which basically acted like a latching switch that was closed/short circuit. He put the battery in and said it booted up once and then died, not realizing his switch soldering mistake.
I've since fixed the switch so it closes momentarily. Battery is fully charged and the LED lights when tested with the battery. I've tested voltaged on the pins at the NB and I'm getting the same voltage at the speaker leads as the battery. Is this normal? Will a shorted switch cause a major issue w/the NB?
Thanks,
Lendo
