Results 1 to 10 of 57
Thread: LED blade diffuser
    Youngling meiv4's Avatar
    Oct 2005
    A simple speck in your vast imagination
    168
    Default LED blade diffuser
    Has anyone found a good one for the 1/8th walled blades yet? as soon as you stock it ill order it []
    hmmm hmmmm whooosh hmmmm whooosh crackel
    Oct 2005
    3,521
    Working on it..as soon as I stock it I can sell it[]
    Hey Strydur,
    what do you do to make the blade diffuse on the one in the turotial?
    Oct 2005
    3,521
    That was the stock mr blade.
    I looked on the mcmaster.com website and found a 3/4 od 1/2 id 1/8th thickness polyethyl tubing in translucent white(misty colored) that with a bit of greasingmight pull thru the polycarb blade. would be mostly seethru and would hold the color lighting pretty well according to the website, has a nice flex and durability rating, and a long life crack resistance.
    Flexible Polyethylene Tubing
    Polyethylene Material LLDPE (Linear Low-Density Polyethylene)
    it is sold in feet and would prolly be a great buy.
    would you agree with my findings?}
    We are the Devourers of Worlds and Little Children
    Oct 2005
    3,521
    I am pretty sure I have ordered every 3/4 tube mcmaster sells. The only thing that would fit inside my tubes was the 3/4 hdpe and it dims the light too much. I am working with a plastics company to have a tube similar to what mr uses on the inside made.
    so you find that the MR Blades work pretty well with the LEDS?
    Oct 2005
    3,521
    They work good..but they arent very strong..so for now they work until I find something I am happy with.
    what about the film that ultra uses? he makes the completed blades in varying thickness of outside tube walls and puts the film in there.
    just a thought strydur.
    Oct 2005
    3,521
    I think you are talking about corbin's blade film. It works ok but it can be a pain to install and has a seam. I will wait till I find what I consider the perfect diffuser.
