Results 1 to 10 of 11
Thread: help with fx sb wiring.
    Default help with fx sb wiring.
    help please... im lost. tried so many combo's and dont want to fry anything.
    this is a sb from a fx hasbro 2010 vader.
    if someone could tell me how to wire it on my stunt saber thatd be great.
    also do I need to use a momentary switch? if so can I use a led one and how do I wire it.
    try this thread
    http://forums.thecustomsabershop.com/-Cheapy-Hasbro-Wiring-Diagrams
    Its hard to tell by your photo but the PCB might have the solder spots labeled. I hope you recorded what wires went where before you cut them.
    Thanks for the link. I have looked at so many different threads now. Non of them seem to have the same wires as mine. I know what all these went to just need to know how to wire it to my saber now....
    All the diff colored ones went to the LEDs
    the blue says A and purple says B go to the clash.
    Red and black too batteries
    Yellows to switch
    Greens to speaker
    Grey says vss?
    Then of course the pointless on off and try me switch.
    Still not sure how to wire it up to work best.
    Quote Originally Posted by e13azar View Post
    Is there anyone that has worked with this exact board that can draw out a wireing chart for me? I'm having a real hard time lately trying to figure this out. Don't know why normally I'm real good about this stuff....
    I wish I could help you, but I've given up trying to figure out all the eleventy million varieties of the FX/Hasbro saber boards. I can tell you that there is *probably* a thread detailing the wiring for your particular board, but it'll take you some time to find the exact one you're using.
    Default Thanks
    I appreciate it. Where do you think I should start looking?
    In the meantime. If anyone else happens to know how or knows where to find it. That'd be awesome.
    I'm in so much pain anymore I have a hard time thinking straight and figuring things out I used to be able to figure out.
    http://forums.thecustomsabershop.com...3w-conversions
    http://forums.thecustomsabershop.com...saber-Versions
    Check through those two sections. If the diagram is anywhere, it's likely in there.
