Ok, so I know the noob list says start simple, but I decided to add a bunch of extras, since shipping is pricey to South Africa. I will hopefully be placing my order around January.
Saber basics:
Blade holder 11
with "new style" heat sink V2
Recommended 8-32 thumb screw
Hilt style 3 with standard switch hole
Pommel style 8, MPS clip and pommel insert style 3 Changing pommel insert style to 6
Star thermal tape pad
Build your own Seoul P4 Electronics kit:
4AA battery holder I will be using 4x AA NiMH batteries here
Seoul P4 (red)
5(degree) lens
4.7ohm 5w resistor
(swithc02) Push on/Push off switch
P4 lens holder
Corbin style 36" show blade 1"OD
1/8" heatshrink
Tap Handle
(The 8-32 drill bit, tap set in out of stock, hoping it will be in when I order, otherwise ill go for another size)
Extras:
Covertec clip,
1" hilt safety plug
8-32 x 1/4" socket head screw
MHS choke style 3
Sound electronics:
16mm Anti Vandal Momentary Nickel plated switch -- Will this fit on the handle I have chosen, or will it require drilling?
Alternatively, should i just take the momentary switch with the LED kit? swapping this for the standard momentary switch with red button
2.1mm Power jack -- Will greatly appreciate a diagram of how this should be wired in
Kill plug style 5
Premium Speaker
Nano Biscotte Sound Module V1 with Light meat sound
2.7 ohm 10w resistor
24 gauge wire; 3 feet both red and black, 2 feet blue and green
Adding the 2.1mm plug adapter for smart charger. By some luck I already have a smart charger.
Did I get everything, or what should be added?
I suspect that ill need extra wire. Which would be best to get?
With regards to the blade retention screw, do I drill the hole at a 90(degree) angle to the blade holder?
That's all for now. Will ask more as questions come up.
Thanks in advance everyone.
I will update this post as I get more info, and maybe swap parts
