Results 1 to 3 of 3
Thread: jedi xami letsab has returned as AfroJedi. new parts list.
    Default jedi xami letsab has returned as AfroJedi. new parts list.
    these are my parts list:
    MPS Pommel style 5
    7" Fluted with guarded style switch hole
    Activation box style 19 & Tap and drill services for activation box style 19 (does this go with the Body above?) and with this 16mm Anti Vandal Short Momentary Blue Ring Switch (will this fit in the activation box style 19 and the 7" Fluted with guarded style switch hole)?
    MHS deep ribbed extension
    Screw on LED blade holder style 23
    MHS "new style" Heat Sink V2
    1" Hilt safety plug
    Tap and drill services for the retention screw with 8-32 x .3" Gold thumb screw (with my emitter would this be a good blade retention screw?)
    1x switch 20 black momentary switch $1.99
    heatshrink $0.50 per foot not sure which size I should get?
    resistor for AV switch?.
    Kill plug style 5 will it fit with 2.1 recharge port?
    please check to see what else if any is missing and to see if the parts I have selected will work together, please?
    Hi Guys,
    is there something that I missing, oh yeah Please help out a n00bie?
    Well, you need a pommel insert and an MPS clip to hold the insert in place.
    You can certainly use the box 19 with the fluted body. Or you could get the http://www.thecustomsabershop.com/7-...ctor-P406.aspx and put the box anywhere on it. It's your choice.
    Your parts will work together fine, but you don't seem to have much in the way of electronics? No LED, no power source? You will need a resistor for your AV switch, but the value will depend on how you power your saber.
