You'll need two 2w 1ohms resistors so you can run the 2 blue die parallel with the 3.7v battery.
Also, since you will be running 2 main LED's, you should opt for the 3400mAh Panasonic instead of the 2600mAh pack, for a few bucks more it'll be worth it for the extra runtime between charging.
Your guarded switch should be momentary type, not latching, if i understand your potential upgrade path correctly.
If you intend to have a 32" long blade, order it to 34" long, as a few inches will be set into the blade holder.
You need to add a pommel insert and retaining ring to hold it into the pommel.
Now here is the "trick" you will need to learn. Do NOT order a standard main body piece when using a special blade holder like style 20. Order the blank 7" f/f extension with flutes, and have Tim dry fit the hilt and locate the 2 holes you need so they align properly where you want them located (aligned top/bottom/side of blade holder) This is more a cosmetic thing to make the saber look cleaner, and the price difference will be minimal. Since you already have other special work being done, this will not delay your order any more than it already will be waiting for your turn in the shop.
