Parallel wired battery packs are fine. You can have a dozen cells in parallel if you have the room.
It sounds like the batteries are low. Did you charge them yourself, or are they still on the original charge from when you purchased them? Li-Ions aren't typically shipped with a full charge.
Also, make certain your battery pack is wired in parallel. Check the voltage with a multimeter if you have one. If the board is getting too much power, you could get results like this as well.
The SD card seems to be working fine, since you have sounds being played. If the card were defective, you only hear a beep or two.
Double-check all your solder joints and see if anything appears loose. Make sure none of your wires have been damaged or have the insulation rubbed off.
