Results 1 to 10 of 20
Thread: My first build for a Revan Saber.
    Default My first build for a Revan Saber.
    Well here is my first build. Am I missing anything? In case I am what do I need?
    MWS Pre-Wired Nano Biscotte Sound Module
    MHS speaker and 2x AA battery holder x1
    JST Extension x2
    JST connectors
    Tenergy Li-Ion 14500 Rechargeable AA size 3.7V 800mAh x4
    Dual 24 gauge wire x4
    Pommel Powder Coating (PM31)
    Hilt style 1 with standard style switch hole
    Screw on LED blade holder style 18
    MHS ribbed extension
    MPS Pommel style 3 v1
    MPS Insert style 6
    16mm Anti Vandal Momentary Nickel Plated Switch
    8-32 x 1/4" Set screw
    Machine recessed AV switch hole
    Price: $10.00
    location: Same location for switch hole on Hilt style 1.
    Drill & Tap Hole (8-32)
    Price: $7.50
    Blade Holder Powder Coating (B181)
    Extension Powder Coating (RIB3)
    Seoul P4 LED & MHS Heatsink Module
    Jul 2012
    584
    Looks pretty solid. If you're using Li-Ions in a 2x AA battery setup though, you'll want to get a dummy cell since the NB only needs the 3.7V of one battery to run.
    Also do you want a covertech wheel or D-ring for attaching to your belt? Completely optional of course.
    MPS clip for holding your pommel insert in place.
    Also a li-ion charger, if you don't already have one.
    Charger check!
    I just realized I need a buck puck. The P4 says 800mAh but the puck only has 1000 and 700. Which one should I get? And what is overdriving an led and why is that good or bad?
    Youngling Jordandau's Avatar
    Dec 2009
    North Hollywood, CA
    220
    You don't need a driver with the nano, just the correct resistor. It's far cheaper and smaller that way.
    You actually can't run a buckpuck with the Nano (without some crazy wiring at least) because the Nano uses 3.7v and the puck needs a minimum of 5v. Resistors are the way to go with a Nano-based build.
    Overdriving an LED is when you run it at a higher current than it is rated for. For instance: running a 700mA LED at 1000mA, or running a 1000mA LED at 1200mA (or more). This will usually increase the brightness of the LED, at the expense of a shortened LED lifespan. You also get increased heat and a reduced runtime. Some LEDs are more tolerant than others. I know the Rebel reds used to be very intolerant of overdriving, and would actually dim or burn out if you tried.
    Is that why the Ultrasabers don't hold a charge on the batteries? I have an ultra that uses the buckpuck w/ Li-Ion setup. If I leave the batteries in then they discharge over a day. I looked for wiring diagrams but I can't find anything that is really recent or I know what it is (Corbin saber?). Can you help me out? This is also my first attempt at building anything electronic.
    Ok fwd voltage is 2.5 so would I use the 2.2 ohm: http://www.thecustomsabershop.com/22...istor-P11.aspx
    or use the resistor chart? It says to use the 1.5 ohm 2 watt resistor. But has no sound card listed in the diagram. I am so confused right now. I have no idea what I am doing. But I do want to build my own.
    The Nano doesn't have a current regulator on board, so you have to use something to regulate power. Whether you use a resistor, buckpuck, LED driver, or something else is up to you. Unfortunately, since the Nano uses a single li-ion, you can't use a buckpuck. The buckpucks won't run on less than 5v, so you'd need a minimum of 2 li-ions to power it.
    Resistors are the least expensive, and smallest solution for regulating power, and are ideal for use with a Nano-based saber build.
    I don't know why your Ultrasaber doesn't hold a charge. If it has a 2 li-ion pack and a buckpuck, it should run just fine. It may be an issue with poor quality batteries.
    But how do I know what resistor to go with?
    Quote Originally Posted by DarthBrute View Post
    Sounds to me like it is time for you to get familiar with Ohm's law... Do the calculations, you must and get your answer, you will.
